- Massachusetts
Here is another makers take on the subject.
Radionic Industries
Radionic Industries
Trigger Start:
Trigger start is a term used for ballasts which operate pre-heat start lamps in a rapid start manner. They supply higher filament voltages to heat the electrodes to start the pre-heat lamps, to simulate the rapid start system. A grounded reflector close to the lamp, together with a grounded line circuit, is required to provide a capacitive starting aid effect between lamps and fixture and assist ionization in the starting process.
Rapid Start:
Rapid start ballasts provide the proper energy levels to heat the lamp filaments continuously, through small low voltage filament windings. The open circuit voltage of the ballast is adequate to start the lamp only after the filaments have been heated to emission temperature. A grounded reflector close to the lamp, together with a grounded line circuit, is required to provide a capacitive starting aid effect between lamps and fixture and assist ionization in the starting process.
Q: What do I do if my fixture lights sometimes and not others? Or, what do I do if my fixture lights if I touch the bulb?
A: This may be a grounding problem either with the way the fixture is wired or if your house does not have properly grounded circuits. Rapid start and trigger start ballasts MUST be grounded (both the ballast and the fixture) and the lamp must be within ?" of grounded metal (fixture or reflector). We suggest you hire a licensed electrician for safe diagnosis and repair.
