The question boils down to:
whats an acceptable level of leakage current flowing on the equipment ground of a hard wired appliance?
If a water heater has a 30A inverse time breaker it will probably let 30 amps flow on the equipment ground indefinitely.
If you touch the metal frame while 30A is flowing on it and the EGC is intact will you feel anything? Will you be shocked?
