mbrooke
Batteries Included
- United States
- Technician
I hadn’t thought of it, but that green cord could be just that, green.I'm guessing that the EGC is actually in the cord.
Could they be hydraulic motors and lines?
Yes, my vote would a controls cable of some type (Profibus / Interbus / CAN / etc). Or maybe a (simpler) temperature and or brake wiring?I hadn’t thought of it, but that green cord could be just that, green.
Control feedback cable?
Like Kwired asked - I wonder what it is exactly that we are looking at?
I have seen this done in a few industrial situations where grounding is critical and a "supplemental" ground is run to equipment in addition to the equip ground in the wiring method.
Yeah I've done some large PV systems where the designer was a green wire cult member. everything already had a wire EGC, but then there was this other green wire that went around and bonded equipment, cable tray etc again.I have seen this done in a few industrial situations where grounding is critical and a "supplemental" ground is run to equipment in addition to the equip ground in the wiring method.
Seen quite a few on natural gas facilities for such reason. I’ve asked questions as to why it’s there, when it already has a EGC in the cable and conduit is attached with a bonding jumper to the cable tray, which in return is connected to the station grounding grid.I have seen this done in a few industrial situations where grounding is critical and a "supplemental" ground is run to equipment in addition to the equip ground in the wiring method..
I've never quite understood the need for term "equipment bonding jumper". Why can't it just be an EGC?I believe those would be bonding jumpers and not equipment grounding conductor.
