mbrooke
Batteries Included
- United States
- Technician
Who wrote this and why are they using the term "earth wire"? The author has no clue.![]()
The same guy who wrote Reefer Madness, probably.Who wrote this . . . ?
Ever hear of the UK? That's what they call it on the other side of the pond. Kinda like bonnets on your car, riding in a lift....
IMO since the NEC uses the term equipment grounding conductor that's what should be used.
It makes it sound like the EGC is to merely bypass a person, while we know it's to trip a breaker or fuse.
That's my point if you call it an earth wire it sounds like if you connect the wire to the earth everything will be fine because the fault will travel safely into the earth which is untrue.And a ground rod won't do squat.
The author is British - as I am I...................Who wrote this and why are they using the term "earth wire"? The author has no clue.![]()
Indeed there is.There’s a great big world out there doing their own thing.
I skimmed through it, and its written with terms that are clearly from GB/UK.
I don't know what that is.Except the way its written goes against even their own rules. A TT supply would have an RCD or in the old day a VOELCB.
They (and EU) have their own version of the problem, in that they call it "Protective Earth"Ever hear of the UK? That's what they call it on the other side of the pond. Kinda like bonnets on your car, riding in a lift....
Good to hear!Some have moved on calling it CPC- circuit protective conductor.
Good to hear!
