Let me throw my thoughts in here solely so I can be corrected if I am wrong. I am not being rude, just trying to learn.
cadpoint said:
Article 100 - Ground. The earth NFPA 08'.
Based on the above quoted definition of ground, the following statement is not correct, it is misleading, and an old wive's tale that has confused many electricians and muddied the waters of grounding and bonding for the last 100 years.
cadpoint said:
Because the basic circuit(s) of AC or DC needs a ground for some form of work to be done, IE it completes the circuit.
A flashlight does not require a connection to the earth to work. Electrical circuits on a spacecraft which is halfway to Mars do not require a ground to work. The service on your house does not require a connection to earth to work.
Electrical work can be done without any relation or connection to earth.
For current to flow, all you need is a potential difference and a path which allows current to flow. This could be a solar cell with a wire to a load and another wire back to the opposite side of the solar cell.
cadpoint said:
Thus one needs a ground, yes a battery is shown in diagram.
I can build a generator which will power a lamp and completely isolate the entire thing from earth. A path through earth is not necessary for a circuit to work.
cadpoint said:
The earth's core is a bigger electron draw that we use to help complete a circuit.
Incorrect. This is one of the most misunderstood thoughts out there.
Electrons from a voltage source will leave the negative terminal and migrate in a completed path to the positive terminal. There is no need for the earth to play any role in this.
The electrons coming out of a generator do not want to go into the earth. They want to travel toward the opposite side of the power source.
The lights on an airplane will work without ground. (Note that AC voltage will regularly change the polarity of the terminals and the electrons will migrate one way, and then the other way, on and on.
Someone above noted that electronic circuits often use the term "ground" as one side, or perhaps the center point of DC sources. This is a totally different usage of the term than what we as electricians are doing. This has definitely messed things up with our thinking.
