dwcaveney said:OFF SUBJECT
i dont think you know what your talking about. there is no such thing as a two way switch. a 3 way switch is a single pole double throw switch. 3 way switch is just a trade name we use when we go to the store and buy them. you could order a single pole double throw switch but all you would get is a "3way" switch. im not sure where the name 3 way came from, maybe its because it has 3 terminals on itdwcaveney said:Ok,
We are getting no where here.
A three way switch is a system that controls a load with two switches.
It just so happpens that two components of the switching system are SPDT switches.
A two way switch is also a system that controls a load with two SPDT switches.
Operationally they perform the exact same function, but the are wired differently.
The two-way has two current paths, the three-way has three.
If you can't accept the fact that it takes two SPDT switchs to make a three way and can't understand #65. Then we are done here.
Good Luck
dwcaveney said:It takes 2 SPDT switches to make one "Three Way Switch"
480sparky said:So when you go to the supply house and ask for "A 3-way switch", this is what they give you?
so you just buy one single pole double throw switch from home depot?dwcaveney said:YOU CAN ASK FOR WHAT EVER YOU WANT. I pick up what I need to make a three way switch in the house I'm working on.
dwcaveney said:Like I said two hours ago. I got work to do .
dwcaveney said:Hey you just proved it, one SPDT switch is a 2 way switch.
And that is a FACT
And that is a FACT
i never heard an electrician the term 2 way switch. only time ive heard it called that is when the happy homeowner is describing something. one single pole double throw switch is one of thesedwcaveney said:Hey you just proved it, one SPDT switch is a 2 way switch.
And that is a FACT
electricalperson said:i never heard the term 2 way switch. only time ive heard it called that is when the happy homeowner is describing something. one single pole double throw switch is one of these
ALSO KNOWN AS A 3 WAY SWITCH NOT A TWO WAY![]()
rattus said:Smoke and dust won't get it. You must back up your statement with something more than your own interpretation. Failure to do so just emphasizes the fact that you are wrong.
iwire said:Really? A Fact?
Better tell all these companies that sell SPDT switches and call them 3 ways. :wink:
3-Way switches
And that is a FACT
thats the best picture i could find that shown the terminals. i never heard uncommon terminals either but it doesnt really matter that much. its just to get to the point of what a 3 way is480sparky said:
dwcaveney said:Hey, Bob is a transfer switch a three way switch?
You are wrong! Now the hard part?
