It would be very refreshing to have an honest debate without games and deflections.
Well, just answer the question in a straightforward manner.
Rather than editing after the fact: φ0: 0, π/3, 2π/3.
You are using a legitimate mathematical transformation, but then trying to defend it as though it was a physical transformation. Stick to your mathematical transformation and all would be fine. But it would be really nice and really helpful if we could carry on an honest debate following proper debating etiquette.
Well am I right or wrong? Is the phase of [-sin(wt + PI)] wt, or is it (wt + PI)?
Neither.It is -(wt+PI).Because -sin(wt + PI)= sin[-(wt + PI)].So,what is it you are right or wrong?
You mean for extremely small values of 'wt'?It seems I have an extra PI in the expression. It should read:
Well am I right or wrong? Is the phase of [-sin(wt)] wt, or is it (wt + PI)?
Since when do diodes care about phase? They don't. You misrepresent this as though phase was critical to the function. The reason why it works has nothing to do with how you measure the circuit. Diodes only care about being forward or reverse biased.If there isn't more than one phase, why does this circuit need two firing pulses per cycle to work correctly?
Actually, I see these are SCRs, which really makes this an asinine question since they can be triggered by anything, and you don't show the triggers. Nevertheless, the above comment is still true.
No, to say that it is phase dependent is a misstatement. Diodes are 2 terminal devices and do not care about phase. They only care about the polarity between those terminals. The way the question is worded specifically makes it appear that the system can only function if you view the voltages as phase opposed versus inversions. That is the part that is deliberately misleading.The circuit containing the diodes, SCRs, or other switches is very much dependent upon the phases connected to the circuit. This is why rbalex's comment that a hex-phase supply is nothing more than a "glorified three-phase" source is a useless description. This description does not improve communication.
Phase (of a periodic phenomenon ?(t), for a particular value of t) The fractional part t/P of the period P through which ? has advanced relative to an arbitrary origin.
[IEEE Std 100 The IEEE Standard Dictionary of Electrical and Electronic Terms]
Note: The origin is usually taken at the last previous passage through zero from the negative to the positive direction.
Besoeker supplied the following graphic is Post 2165 and accepted the following definition in Posts 1537 and 1539:
Definition:
The actual definition is underlined. The parenthetic clarifies that the definition applies to periodic phenomena. The ?Note? states a non-mandatory convention.
In the graphic I see six periodic functions ? so the definition applies.
Since time is the only independent variable; I choose a common t0 = 0 as the ?arbitrary origin.?
At t0 = 0, two of the functions are zero and have identical periods of 360?. Throughout the period P, at any time t, they have the identical ?fractional part t/P of the period P through which ? has advanced relative to an arbitrary origin? (t0).
Therefore, those two functions have the same phase.
For those that feel compelled to evaluate this analysis by dredging up and applying an alternate definition of ?same phase,? in the statement above, same is simply an adjective under definition 1a in the link. The ?relevant? factors within the definition are they are periodic functions with a common t0, initial value and period. How this may or may not apply to other sets is NOT relevant to conventional 120/240V systems.
Yes - so? That isn't a requirement of the definition. What part of 'The “Note” states a non-mandatory convention," don't you understand? Or did you even read the definition?Nonsense!
There are three pairs of inverses. Their zero points coincide, but their negative to positive crossings do not.
There are six phase constants, count them, six phases.
Yes - so? That isn't a requirement of the definition. What part of 'The ?Note? states a non-mandatory convention," don't you understand? Or did you even read the definition?
If I may reword: Transformer connection are what they really are. The physical relationship between a transformer's terminals output are based on the reality of its connections.
Echoing back what I got from your wording: The assignment of voltage directions is mathematically equivalent to a phase shift.
I would contend that your inference is not based on the evidence. It would not be possible for one to use the transformer configurations in my examples if one were to ignore the physical realities of the transformer connections.Summarizing, what I infer from your wording:
The "physical realities" of of transformer connections can be ignored, it is only the arbitrary assignment of mathematical references that counts.
Thank you. This is correctly stated.Almost. The assignment of voltage directions is mathematically equivalent to a time shift. While they are not time shifts, taking voltages from different terminals and in different winding directions produce what we refer to as phase shifts.
The reversal of polarity indicated does happen, but it happens at the output by the attachment of the connections to the transfomer.
I have been saying I have both added and subtracted windings to change voltage as needed...Many different voltages and phase angles can be obtained.
In the single phase example, an infinite variety of connection changes can only yield two different phase angles, 0 and 180, which is the special case of reversal of the leads polarity. All sums add linearly and there is no phase displacement in a second dimension. The 0 to 180 deg rotation is a one dimensional solution on the same line.
