120113-1401 EST
Besoeker:
I may have two, but at least one scope with direct access to the deflection plates. But I have never made direct connection. My two newer scopes, Tektronix, have no easy connection to the plates.
Then I have a Dataq data acquisition device that has 16 inputs or 8 differential inputs.
The one scope that I have that definitely has direct plate access is one I built from a WWII surplus 5BP1 CRT tube. Made it in two days, could see sine waves on it, not very wide bandwidth, just audio. I believe my Heathkit scope has terminals on the back for direct plate connection. Much of my older equipment does not work correctly or not at all. A Heathkit audio VTVM, and audio oscillator are still working. Whereas a slightly newer HP oscillator and several VTVMs are not working. Some time I need to fix them.
