AdamTeeScott
- Louisville, KY
- Electrical Contractor
I work on some old houses with plaster walls/ceilings and I occasionally run into knob and tube wiring. Occasionally some of the homes have BX cables run to the electrical boxes, or it will be half and half.
In any case, when I am trying to determine which conductor is the hot wire in an old ceiling box, for example, because the insulation is not colored, I tend to pick up voltage imbalances on the neutral conductor, some as high as 65 volts, which triggers my non-contact voltage tester.
Where would such an imbalance come from when nothing is plugged in and turned on and how, if possible, can I dissipate it, cancel it, 86 it, get rid of it, etc.?
