- Wisconsin
- PE (Retired) - Power Systems
Correct only when considering the source itself. However, a neutral voltage point can be derived by connecting a wye load having balanced impedance from each line to the common point?which is a "neutral point".
My comment was directed to a 3-phase transformer bank connected in a delta - the load connection is a separate and for the most part irrelevant issue. There are enough mis-perceptions about delta transformer bank secondary connections without having to go off topic.
