Wifi extender
Buck Parrish
NC & IN
I'm building a shop / garage about 75 yards from my fiber-optic wifi. Has any body got experience sending the signal that far wirelessly. It's about 75 yards to the shop.
If it were my shop I'd want to do a trench and run a PVC for power and comms as well as water etc. I'd then pull in at least one cat6, probably direct burial rated.
I am, but my power water and sewer is near the shop at the other direction from the wifi
Honestly, I'd bury some CAT6 and do a wire bridge over to the shop and then go back to wireless. That's what I plan on doing once we get the new house underway in the future.
like Texie said, a UniFi bridge is the way to go here. $500 for the parts.
You could lay some Cat6 in the ground and install an AP in the shop, but you wouldn't save any money.
I had my LV guy install one on a project a few weeks ago to link a detached pool house. Its about 130 yds away, head of pine trees between the house & pool house and it works great.
The down side to running a UG ethernet in addition to the trenching is that it has to be rated cable plus to be compliant you also need lightning protection at each end.
