Eddy Current
For instance a drill battery or does it depend on the type of battery?
No and no. I learned the hard way too.For instance a drill battery or does it depend on the type of battery?
Not many lead acid batteries in drills........No, there would in fact be deep discharge cut off circuit in well designed lead acid dry type battery power supply systems.
But they are not tolerant of high temperature due to any deep discharge as a result of continuous high current.And NiCads are tolerant of deep discharge.
A common mistake with discharging NiCd batteries is that the person over-discharges them. Don't run the drill until the motor barely turns. This over-discharges the battery pack. This can cause cell reversal, and that will destroy the cell.
The most common way to kill any type of battery is to leave it on the charger after it has been charged. Even an intelligent charger that switches to maintenance mode after fully charging the battery, the battery should not be left on the charger for extended periods. If it's a non-intelligent charger, then the battery should be removed as soon as it is charged. If you want to extend the battery life of your cell phone or laptop, then don't leave them plugged in all the time.
NiCd and NiMH battery life is dependant on how many charge cycles they have experienced. That even includes partial recharging. So for these batteries, it is best to run them through full discharge and charge cycles.
As for Li-Ion, the less fully charged they are, the longer they will last. There were a few posters that stated to always keep them fully charged. This is not correct. Their lifespan is based on calander-age, but will be reduced if they are kept at full charge. These batteries are not affected by how many times they have been recharged; only by calander age. But if they are not being used, it is best to not recharge them until they are needed. If they are going to be stored for a long time, it is best to have them at about 50% charge, but monitor them to ensure they do not drop too low. They have a very low self-discharge rate, so they can be stored for quite a while before they drop below their minimum voltage and their internal circuitry disables them permanently.
Nickel cadmium batteries should be fully or nearly fully discharged from time to time or they tend to suffer from a memory effect that reduces the capacity.
Nickel cadmium batteries are not much used these days.
I agree with this statement, But why did you reverse this below????
I don't agree with this if you are using the manufacture supplied charging unit, I have yet to find one that continuously charges after the battery has reached full float, everyone I have tested shuts off the charge and only turns back on when the charge level on the battery has dropped to a certain level it then comes back on at a maintenance charge level which in most cases is a much lighter charge level then when doing a full charge, if the battery has bad cell or two some chargers will keep trying to charge it back to full float but it just never reaches this voltage so it never kicks off, but smart chargers will detect this condition and shut down, my Dewalt charger will start flashing really fast when this is detected.
NiCd and NiMH battery life is dependent on how many charge cycles they have experienced. That even includes partial recharging. So for these batteries, it is best to run them through full discharge and charge cycles.
Why the reversal of your first sentence?
As for Li-Ion, the less fully charged they are, the longer they will last. There were a few posters that stated to always keep them fully charged. This is not correct. Their lifespan is based on calender-age, but will be reduced if they are kept at full charge. These batteries are not affected by how many times they have been recharged; only by calander age. But if they are not being used, it is best to not recharge them until they are needed. If they are going to be stored for a long time, it is best to have them at about 50% charge, but monitor them to ensure they do not drop too low. They have a very low self-discharge rate, so they can be stored for quite a while before they drop below their minimum voltage and their internal circuitry disables them permanently.
A smart charger will actually turn itself off when the battery reaches a full charge. Periodically, the charger will come on so it can check the voltage, then decide if it's time to charge or not. If not, the charger turns back off and waits until the next go around.
That's different than a float charge, which is a small, but constant maintenance charge. That keeps the battery charged, but shortens it's life. Before smart chargers we (ham radio / emergency service types) would use float chargers, but put them on a timer. That made all the difference in the world.
I have two smart chargers, one I use as a charger and a small 6w that I use as a maintainer. I have a pigtail on the battery of my Harley so I can keep the smart charger connected all winter. It's not much fun taking the battery out. I also have one on one of my vans so if I let that sit I can keep a charger on it as needed.
Neither smart charger will turn on if the battery voltage is too low. I play with batteries a lot and squeeze every last electron out of them before they go to the recyclers. One trick is to use a charged battery to force charge a totally dead one enough for the smart charger to turn on.
The larger of the two chargers has a fault code readout. You need some savvy to know what they mean, but if you do it is possible to fix some of the problems and get a full charge with no codes from a not so good battery.
