olly
- Berthoud, Colorado
- Master Electrician
In an un finished basement is there a rule that you must stay below a certain distance way from the bottom of the subfloor when running wires through the floor joists? Its an old home with 2 x 8 joists and with duct work it seemed better to run over the top because if I went low the wire would extend below the bottom of the joists.
I made sure all of my holes through the joist were 1 1/2" from bottom of subfloor to top of electric hole.
Where I ran over the duct work it is within an 1" of the sub floor.
I am wondering if the inspector will have the right to say something about it?
Thanks for your response!
