rswolff001
Client has a 5kva 480/120 transformer supplying 120vac to two separate circuits inside a control panel. I told them to use 8g wire for the secondary to the circuit breakers for the two circuits. They asked if they needed 8g. And I wasn't sure.. can they land the secondary on a distribution block and then split into the two circuits using smaller gage wire based on the circuit they are supplying? The transformer is on the top of the enclosure, so the distribution block would be no more than maybe 1ft from the transformer. The circuit breakers would also be 1~2ft from the distribution block. Can they do the same for the neutral? I know its acceptable for the mains into the enclosure, not sure if its acceptable for the transformer. Thanks, Bob
