James L
- Kansas Cty, Mo, USA
- Electrician
I have a residential job with a gas insert being installed into a wood burning fireplace in a finished basement. A gas line was run into the fireplace when the house was built.
The insert has a blower which needs 120 volts, but there's not a good way to get power in there.
The general contractor is planning to apply a stone veneer over the brick. He wants to use a grinder to remove about one inch of the depth of a horizontal mortar joint, and have me lay a wire in the joint and leave it without mortar. Then apply the stone veneer and cover it.
I told him I will not lay a piece of Romex in that joint, but I'm wondering about a piece of UF cable? I also wondered about covering a cable with a small wire loom to add a small amount of protection.
The mortar joint is just a bit smaller than 1/2"
Any suggestions?
Any suggestions?
