wire nut melted in bathroom light/heater/fan
andylct
yulee,fl
any ideas on a red nut melt down. it had 1 12 gauge neutral to two whites on the heater/fan.
It wasn't correctly installed. That is it wasn't tight enough. You should see some twist in the wire below the skirt of the wirenut. The instructions for one brand tells you to tighten until there are two full twist visible below the skirt of the wirenut.
thanks , but
thanks , but
thanks, but the attached wires were 2 braided copper from the fan unit. am i still supposed to make a twist in the single 12 gauge copper wire?
not arguing, i do believe the nut wasn't tight enough, just asking.
thanks
About the only way that can happen is if the load is greater than the wire can handle or the connection is loose. I don't think the load was greater than the wire can handle.
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC? Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
If you feel this action to be in error, feel free to contact me via PM to explain.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
