You are not supposed to be reading directions. :grin:
And you should always have some extra parts left over.
Is that in the directions?And you should always have some extra parts left over.
I was reading on the back, and it says do not energize until completely dry. I never knew this. So how long should you wait?:-?
I saw a guy use WD40 as lube today.
He said "It works well and the THWN is oil resistant.."
Seemed like a bad idea to me.
I have a whole garage of boxes of extra parts.I have a whole box of those extra parts in my garage.
Chris
I have a whole box of those extra parts in my garage.![]()
I have a whole group of garages filled with boxes of leftover parts.I have a whole garage of boxes of extra parts.
I have a whole group of garages filled with boxes of leftover parts.![]()
IMO this is just CYA info provided by the manufacturer in case there's ever a problem. Like Bob said conductors are designed to be run in wet locations so why should some lube be a problem? Besides, how would you ever know if the lube in the middle of a pipe run is dry?
Except WD40 isn't an oil. It's a solvent.I saw a guy use WD40 as lube today.
Ideal sells blue lube that if you put some on your hands and rub it together a few times, it turns to glue in a matter of seconds. IMO the only thing that particular lube is good for is giving you blue hands. :grin:
