wire pulling lube
Hello all! What is the best performing wire lube you have used? Also what are your thoughts on no lube wire.
It doesn’t matter if it’s the yellow baby poop, blue smurf blood, clear fish slime or some kind of home made stuff. The wire feeder is going to get slimy and possibly stinky. Just accept that and you can get it done no matter what the lube is. I often do solo pulls and when I do unless i can squirt enough lube down that first fitting, there is no way I’m going to lube anyway. A lot of my pulls are dry.
If you feed it properly, address tight bends at conduit bodies, avoid twisting around itself, and don’t have too many bends, you shouldn’t even need lube.
