chevyx92
- VA BCH, VA
I thought that if you were going to identify a wire with phase tape that the wire had to be #8 or larger. Is there any thing in code that says you cant reidentify #10 or smaller with tape?
DittoOriginally posted by tkb:
Supply houses around here don't stock #8 and #6 white or green. Have to make a special order.
I see a lot of reidentification of #8 and #6 for neutrals and grounds.
Yup, they sure would.Originally posted by augie47:
If the inspectors began rejecting jobs which didn't have continuous color identification on grounded and ungrounded conductors, I bet the supply houses would begin to stock #6 AND #8 in green and white.![]()
Originally posted by pierre:
I for one do not see how a second ground rod really makes any difference.![]()
In many areas of the country, this code rule is not complied with. All wire larger than #10 is re-identified. I think this is one code rule that would be tossed out, by a court, if someone with deep pockets choose to challenge it.We all have parts of the code that we do not agree with. But we still comply with them.
