Wire size for DIY mini-split confusion
phdibart
New User
Maine
Nutty professor
I'm installing a MrCool DIY multizone heat pump that can support up to 4 air handlers. The installation manual says use minimum 6 AWG, but the plate on the outside unit says 30 MCA with 45 MOCP. According to many sources, including the one here https://forums.mikeholt.com/threads/sizing-wire-and-circuit-breaker-for-air-conditioner.135804/ , I would be OK with 10 gauge based off the nameplate.
I understand that AC compressors are an exception to the normal NEC ampacity ratings, but I'm hoping someone might have insight into why the install manual would suggest something so out of line with what the plate implies.
Would I be OK with using 10 gauge NM-B from the panel in my basement to a disconnect on the outside of my house, and then a whip with 10 gauge to the compressor? It just doesn't feel right because there's such a big difference between 6 ga and 10 ga wire, so I'm wondering "what am I missing?"
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
Reminder to all members, if you see a questionable post, feel free to report it by clicking "Report" at the bottom left corner of the post.
