Re: Wire Size for outdoor Hot Tub/Spa
Hi Ted,
Just a little insite from a commercial contractor; Most info plates are pretty informative and specific. I have yet to see a name plate that asks me to calculate or assume the full load current based on information presented.
From my experience, the plate provides the "facts sir, just the facts". Unless MCA (min ckt amps) and MOCP (max over current protection) are stated, it would be questionable to assume the given load is anything other than 'full load amps'. My experience is that the use of the item then determines the duty cycle for load adjustment to the circuit.
If this came across my desk and based on concurring discussions, I would spec #6 back to the main panel.
Cheers, and good luck. Jeff
