WIRE SIZE
vweeks
WHAT IS THE CORRECT WIRE SIZE AND TYPE OF WIRE USED TO MAKE A RUN UNDER GROUND THROUGH PVC CONDUIT, TO A MOBILE HOME FROM THE METER POLE? THE ESTIMATED RUN WOULD BE 100 TO 125' :confused:
luke warmwater
Re: WIRE SIZE
First of all, what is the amperage??? ie.100, 150, 200?
There are alot of things missing from your post that makes it hard to answer.
You can't go 100' directly from the meter pole into the home. You have to have a disconnect adjacent to and not mounted to or in the home, within sight and not more than 30' from the exterior wall.....
Extensively read Part III of Article 550!
One availible wire type = XHHW
vweeks
Re: WIRE SIZE
MY APOLOGY,
I SHOULD HAVE MORE CLEAR ON MY QUESTION. THE METER POLE AND SOCKET ARE EQUIPPED WITH DISCONNECT ON THE POLE. THE AMPERAGE SUPPLIED WILL BE 200 AMPS. SO I GUESS IM ASKING WHAT SIZE WIRE SHOULD I USE FROM THE DISCONNECT WITH A 100' RUN GIVEN THIS ADDED INFORMATION. THANKS, VWEEKS
tom baker
Bremerton, Washington
Master Electrician
Re: WIRE SIZE
VWeeks, there is a lot more to your question than we can answer. Keep in mind that:
(from the home page)
This site is from
Contractors
Electricians
Engineers
Inspectors
Instructors
Other electrically related individuals
And we assume a certain level of knowledge on your part.
For example, are you familar with the grounding requirements for services? Clearances on overhead drops? Why a mobile home requires a four wire service?
You may be better off to get an qualified electrican to help you, you'll sleep better knowing its safe.
[ June 12, 2003, 10:54 PM: Message edited by: tom baker ]
