Randy Gulley
New member
When using Table 310-16 correction factors do you use average temperatures in an area or the highest record temp?
Randy Gulley said:When using Table 310-16 correction factors do you use average temperatures in an area or the highest record temp?
charlie said:Consider that three hours or more is considered continuous load. With that in mind, the peak temperature is not a quick event but is usually for a few hours in the afternoon. I would consider the peak when doing the correction. However, since the Code is silent on this subject, so it is up to the interpretation of the AHJ. Unless you are using the peak, I would recommend having a conversation with the AHJ. :smile:
My prediction:Rockyd said:Thinking it will be hotly debated for the next code cycle.
I have found that crow goes well with a cold Bud Lite. I am a connoisseur of crow, especially when served hot with a little barbecue sauce. Trust me, we have all had our share.Rockyd said:Thanks. Did I wipe the last crow feather away? Wasn't bad for a tender serving.
