Situation; Wireless router in an enclosure and antenna mounted on a rooftop AC unit. (convinience store)
Condition 1; POE cable through an arrestor
Condition 2; metal backplate in the enclosure with bonding lug.
condition 3; no intersystem bonding termination.
I want to verify the code requirement for grounding point of attachment.
830.100 A(3) B(2-7) states that the only acceptable grounding point must be at the main service (more or less) I cannot find anywhere in the code that would allow this situation to be grounded to anything on the roof.
It is required to be attached at the building ground (main)
Does anyone have a code section that would even imply that it could be connected anywhere else?
