puckman
- ridgewood, n.j.
Does anyone know of a product that can be used wirelessly to control a motor starter? 120 volt coil. Thanks for the help.
What range do you need, what special requirements (water-proof, damage-resistance, etc.), and what's your budget?Does anyone know of a product that can be used wirelessly to control a motor starter? 120 volt coil.
This really helps the guy????
X-10 stuff could even be used.
We didn't know the particulars after the OP and when I responded. 'Scuse me.X-10 is unreliable/marginal for home automation. I would never recommend its use in a commercial or industrial setting.
Your X-cusedWe didn't know the particulars after the OP and when I responded. 'Scuse me.
I am often amazed by very long threads with only one post by the Original person.
ThanX! :grin:Your X-cused![]()
Do you know how that would impact our post counts?!I would like to see a hold put on threads until the OP responds to requests for more information - as occurs in a lot of cases.
