brielellalyse
is it in the code book that you cannot run wires between the framing and the concret wall in a finished basement. the wires were stapled as support every 2ft
I agree with the notorious post hijacker, Chris. :grin:raider1 said:As long as the wires are properly supported and not subject to physical damage I see no problem with this.
Chris
Dennis Alwon said:I agree with the notorious post hijacker, Chris. :grin:
Edit to add
I will go so far as to say you can fasten NM to the block wall.
raider1 said:Shhhhh! If it gets out that I am a post hijacker I will be on every government watch list and never be able to fly again!
Chris
Dennis Alwon said:This is going to cost you.
raider1 said:All I have on me is some pocket lint and a breath mint.
Chris
480sparky said:You mean like this?
Unless it's right next to the box, I don't staple the NM directly. I just use scrap sheathing.
Dennis Alwon said:Is that sheathing listed for the purpose and how many wires can you legally secure with it????![]()
buckofdurham said:I like that sheathing method. It looks better then bending the wire at every joice to get a staple in it.
I have also used 3/8 one hole straps to fasten it to the concrete.
Never been called on it.
480sparky said:How many cables can I put through a hole in a 2x4, and is it listed for that purpose?
buckofdurham said:No more stapling along the bottom of the joices![]()
buckofdurham said:The 08 code covers that belive it or not.
Somebody will correct me but I think it's two.
infinity said:Are 3/8" one hole straps listed for flat NM cables? We always use the special flat NM style straps when strapping to a wall.
Dennis Alwon said:Your fellow workers will kill me if I take the breath mint and being I am not into pocket lint I will let it slide this time.
