Cow
- Eastern Oregon
- Electrician
This must be the job you were asking about the big power dist. block for in the other thread? What are they using in there now for all those disconnect taps? Split bolts?
That's a good question, it is gasketed and under a porch (for the 2nd floor). Maybe it has a 3R rating with the gaskets?
Yes, it is.This must be the job you were asking about the big power dist. block for in the other thread?
The screws on that cover are very rusted, I was able to remove a small section cover on the far right, very rusted screws. I looked back in the gutter and could't see the connection.What are they using in there now for all those disconnect taps? Split bolts?
So I was looking for a connection method that will fit in that gutter and stay in compliance. It doesn't have to be a terminal block.
If the bottom of the wireway is at 6'6" or less and the wireway is more than 6" deeper than the equipment, there is a 110.26(A) violation.
