shamsdebout
- Macon,GA
Anyone ever did work for Wet Willies or resturant that has a slushie/margita machine, if so please explain how your wired it up.
I have included some pics of this unit, it comes with a 10' plug, would you install it with the plug or hard wire it, and if so how you do it.
I opt for the higher voltage whenever practical to do so.It's comes with a cord so that's what it would use. It looks as if it comes factory wired for 120V with the option to use 230.
So I would give it a dedicated 20 Amp. 120V receptacle.
Just looked again, the option 230 at 50 hertz must be for over seas use. Keep it at 120V.
Margaritas. One is never enough and two is too many.
OP what is the issue? and what sort of receptacle accepts a 10 foot long plug?
Put a 20A 220V single recept. on the wall and pour yourself a frosty.
- Voltage: 115 -- Opt. 230
- Hertz: 60 -- Opt. 50
- Amperage Draw: 6 amp
- Circuit Breaker: 20 amp
- Plug Configuration: 230 volt, 20 amp
NEMA 5-20
This unit requires an install by the refrigeration guys, this is just the dispenser unit there is a seperate condenser unit that goes someplace ( probably outside). It has a refrigeration line that must be connected.
They do mention that three dispensers can be hooked to one condenser.
The reason that I would use 120V is that it's available and on the other hand there is probably only 208 if this is commercial and the machine is listed for 230V. The 120 is one of the operating voltages that's listed on the name plate. It will work fine on 208V but I like to stay with name plate listings if possible ( warranty and all that crap ).
These units are only 35" tall. Just mount the receptacles in the wall above the units. Like everyone does in commercial kitchens for the refrigerators.
And what is even MORE important - This machine has the capability of putting out ......
320 10oz drinks an hour !!
Thats more then even more then Jimmy Buffet can handle!
Raise you hand if your thinking Hang over
It's hard to tell how the machines are wired in the posted pictures. I would need to see the backs of those machines. Whats behind the panels over the machines? Is there access to that area? Do those machines pull out easily?
I did a laundry mat that had the machines lined up the same way, with a partition over them to make it look built in. There was access to the backs to get to the power and water. Could this be the same type of set up? They could very well be hard wired,but someone had to get to the connections to do it. I would request more information if I were you
This has got to be the most OT deleted post I have ever seen.
Please don't let this drive you to drinking.
What's funny is that you even deleted some of your own posts as OT, so at least you understand how it happens. :smile:It seemed to me that the OP deserved a little more than 7 honest replies and 28 - 30 posts on drinking.
- Phase: 1
NEMA 5-20
