Trying to wire a motor. Due to tight space, I have to use 2.5" conduit at the max. 275A FLA motor.
I initially thought of using parallel conduits. They issue with doing so is that my controller has only two terminations for ground. If I use parallel conduits, I won't have any ground terminals for my input power.
Based on the amperage, I need to use 500MCM
Is there any way to do this and fit it in 2.5 with a ground? The only thing I could think of is using aluminum conductors, and I've been told that is frowned upon (is it?)
I saw different tables in the NEC for "fixture wire" and "compact building wire". What's the difference?
