Wiring for subpanel120v.
the919
New member
New to the forum, so thanks in advance for the responses.
I have a 90amp circuit breaker in the Main panel for the heat pump. In the attic where the heat pump is located i have a subpanel that splits this circuit into 30 and 60 for heat pump and emergency strips for heat pump.
Wire from main panel is aluminum 2-2-4 (2 hot + ground). I need to convert subanel to 120/240.
Can I install a neutral bar in the subpanel and run a single #4AWG insulated copper wire from main panel neutral bar to a subpanel neutral bar to get my 120v?
So final wiring will be aluminum 2-2-4 and copper 4 neutral.
I will be removing emergency heat strips so 60amps will be available for 120v service.
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC� Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
If you feel this action to be in error, feel free to contact me via PM to explain.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
