wiring method
jemsvcs
Concerning wiring in wood frame (pole) buildings that are detached and used as a residential garage...
I have always used emt in these situations but some locals use nonmetallic cable only. Any thoughts?
Re: wiring method
My only concern would be protection from physical damage. Other than that, I see no real issue with using NM for this particular installation you describe.
Re: wiring method
If you bid jobs using anything other nm in my area you will lose the job for sure cause someone else will beat your bid using nm.
