Br4nd0n
- Indianapolis, IN, USA
I need to install a BK Precision 1900B Series DC Power Supply that will output 60VDC at 15A max (900W).
https://bkpmedia.s3.amazonaws.com/downloads/datasheets/en-us/1900B_Series_datasheet.pdf
The load will be a series of cameras installed hundreds of feet away. I don't have a lot of experience installing DC circuits like this and am trying to figure out the proper wiring method for this install - nothing is standing out clearly in the code book to me. My initial thoughts would be that the wiring still needs to be in a raceway (it's not labeled as a class 2 supply, for example), but the outputs are just 2 exposed posts on the back of the device, so this suggests open-air cabling would be ok, but it's not clear to me. Can anybody steer me in the correct direction here, code references perhaps? I'm trying to determine what type of wiring, cable, or raceway, if needed, I should plan to use so I can properly install this thing.
