Brad Baxter
Going into wiring new residential developments. Does any of you have some sites or info as to how i can bid on developments? Any help would be gladly appreciated. thanks.
peter d said:To do this work and make money you will need two things: cheap help, and speed. Forget any notion of doing a quality job that is anything above minimum code.
Brad Baxter said:Ok so you guys are sounding like your against the new sub divisions but that means i should be able to bid them.
Brad Baxter said:how can i get at least a chance to bid them?
Brad Baxter said:Ok so you guys are sounding like your against the new sub divisions but that means i should be able to bid them. any help on where to bid online sites etc. since you guys seem to not want them. how do i connect with these? how can i get at least a chance to bid them?
C3PO said:I am going to have to agree with CEB58. Most developers are going to squeeze you for all they can and it just is not worth it.
But I have done one small subdivision (around 25-30 lots higher end homes)
CopperTone said:We just bid a job - not track homes - public bid - first off 10 EC's bid it. holy moly 10?
here were the results 60k, 88k, 89k, 96k, 98k, 107k, 108k, 109k, 125k, 197k
growler said:I would throw out the 60K and the 197K right off and and maybe kick out the 125K & 88K then only concider the others. It's not so bad if you look at it this way, you have a job that should go for around 100K with some being 10% high and others 10% low.
The six middle of the road bids come in at just over 102K so your company wasn't that far off. Probably as low as you would want to go without taking some real chances.
aline said:...He tells me the electrician he was using before this one went broke and out of business as well......
.Later that afternoon, the builder shows up and asks me if I want to see his 'new toy.' Out in the drive was a brand-spankin'-new Corvette with 12 miles on the odometer
I looked at him and said, "Interesting. You run your business like it's your God-given right to have nice things, but you demand your subs price their work so low they have to drive a rusty '84 Mazda pick-up held together with duct tape and baling wire and live under a bridge in order to barely eek out a meager living."
