dm9289
Industrial Maintenance Electrician
- Pennsylvania
- Industrial process repair/ maintenance Electrician
In my area that has basements it is common practice to put a large piece of plywood on the wall before attaching service panel.
1.It gives you an area to attach romex
2.It gives you a slight barrier with the block wall incase its wet
Is there any other reason to use or not use plywood as a backer, as many know wood is getting very expensive.
Thank you for your input
