worst tool ever made
electricalperson
massachusetts
i bought the greenlee emt cutter, its similar to what the plumbers use to cut tubing with. biggest piece of junk there ever was. dont ever buy it. it caused me almost an hour of aggrivation today because it couldnt cut the pipe right. i bought it to try out and ill never use it again! dont waste your money on this or the klein one
growler
Atlanta,GA
I got one of those Greenlee circuit tracers from Grainger and used it one day ( about an hour) and I took it back because I was not satisfied with the quality for the price. I didn't think much of it.
If I were you I would take it back and get a return. I don't keep tools that don't work anymore.
satcom
When using a tubing cutter to cut EMT the tubing needs extra reaming after cutting, and the cutter can also run anything but true to a stright cut.
raider1
Logan, Utah
the tool claims you can cut and not have to ream.
If you score the EMT with the tubing cutter to a depth about have the thinkness of the walls and then snap the conduit sometimes this will leave an edge that does not require any additional reaming. This is tought to do, so I never use tubing cutters and use either a hacksaw or cordless sawsall.
Chris
boyle78
new hampshire
have any of you used the new mini sawzall from Milwaukee? Our shop got a few a little while back and they weren't worth the money...it seemed that when you put enough pressure on the blade to cut a piece of emt, the thing binds up...we tried fresh batteries, new blades, multiple tries with the same result.
iwire
Massachusetts
Worst tool I ever wasted money on.
get_image.aspx
GreenLee 5715 Deluxe Gas Lamp Tester​
A total waste of time and money.
mikeames
Gaithersburg MD
Teacher - Master Electrician - 2017 NEC
Like others stated, when or if I use a cutter I score half way through and bang the cut side on the ground which "snaps" off the piece. Still needs a ream but much less.
electricalperson
massachusetts
i seen those romex strippers and i probably wont buy them ever. klein needs to get back to making quality handtools and not slapping the klein tools name on every piece of crap that comes through
