To have 1 light fed from 2 S.P. switches, if it was the same circuit there wouldn't be anyway to overload the neutral. The neutral current would flow on both neutrals about evenly with one switch on.
For the record a 3 way would not work either. The possible design is 2 lights in seperate rooms, that are desired to be turned indivdually or with a "master" switch that would do both. Obviously both would have to be off for light to be off.
