Would you consider a drinking fountain a sink for GFCI requirements?
Heelertreats
USA
Commissioning
Hi folks. I’m looking at a water fountain that is correctly protected by GFCI. But there are non-GFCI receptacles installed well-within 6’ of the water fountain. The fountain has what could be called a bowl, an bottle-filling station, a direct drinking outlet and a drain.
I lean toward calling this a sink for code purposes and requiring the nearby receptacles to be GFCI protected, but what do y’all think?
422.5 includes bottle fill stations as requiring GFCI for themselves.
I have called drinking fountains "sinks" before, but they are technically not.
If the goal is to reduce the possibility of shock to someone washing a pluggable appliance in a sink then a fountain in a hallway or similar is not likely to have that occur. It is unlikely someone is going to put a toaster in the drinking fountain for spicy tasting water.
If it is in a break room, it is a tad more likely if someone wanted "filtered" water for the blender or those insta-hot kettles for tea. And it wouldn't be required by code, but rather just a judgement call.
Thanks everyone. I appreciate the insights. The unit in question is one of these standard fountain/filler units, mounted to a column in a heavy manufacturing environment, and there's a quad receptacle about three feet away from the "rim".
However, nearby receptacles would not be safer with GFCI protection.
Lets ask this question:
Do you drink out of sink?
Do you drink out of drinking fountain?
