I’m hesitant to do T&M because I want to maximize my earnings. The job I’m bidding on is a large remodel in a condo with concrete walls and ceilings. There’s a chase down the hall, but it stops halfway, leaving no clear way to run circuits into the living room. The kitchen also lacks a chase, and they want me to remove the wall between the kitchen and living room to add an island. This seems to require significant floor saw cutting to route circuits where they’re needed, which makes me uneasy about providing a fixed bid.
They also want the baseboard heaters moved to the ceiling for a cove heat setup, along with some surface-mounted lights installed.
I feel like I should be able to come up with a number, but my estimate lands around $25k, whereas for a straightforward job, it would probably be $8k–$12k.
Would you approach this as T&M?
