jrannis
- Fort Lauderdale/ Miami
I sure the narrator missed a decimal point when he was reading the script. Could be more like .04 or .40 or something like that
Or 40mA maybe?
That's a lots of watts!I was just watching modern marvels and it was said that the external defib units put out 2000 volts at 40 amps!!!! WOW I had no idea. I figured the voltage would be high so 2000 volts does not shock me, but the 40 amps was mind blowing. If I was forced to guess I might guess 1 to 5 amps. I wonder if patients get burn marks from them.
Sorry to hear that you need such serious medical procedures on a regular basis.Unfortunately, I have been the recipient of over 10 "cardio-versions" to correct atrial fibrillation. I am no way an expert except to say that each time I get converted, I know for a fact that the machine is set at 200 joules. (cause that is what my history says will work the first time). Until they established that number, they would start out a 100, then 150, then 200. Each time, of course, you get another "zap" on both your front and back side where the electrodes are. They have different brands of electrodes and the procedure is highly variable by the techniques of those performing it. Some times, I have had very painful blisters, burns, while others, just some redness and itching.
I don't want to go back again soon, but I will ask my cardiologist about the specifics of the defibrillator he uses in the ER.
For those who are wondering, they tie down your arms and legs and knock you out usually with Brevitol or Versaid. You wake up and hopefully are in sinus rhythm and of course, you have the "marks". Beats being on Coumadin though!!!!![]()
Last year my cousin had an operation to repair a hole in his heart.Thanks for your thoughts......... Up until I was about 55, I didn't have a health concern to worry about. Then after having an irregular heartbeat and after tons of time and visits to the Cleveland Clinic, they found a heriditary condition called IHSS. (Idiopathic Hypertrophic Subaortic Stenosis). My Dad had the same thing but could not be "converted" back to sinus, so he was on Warfarin for years and years. The septum (between the two chambers of your heart) is thicker than normal in my case and often interferes with the electrical signals of the heart. Periods of high stress or exertion can trigger an atrial fib episode. Luckily, I have always had success at cardioversion so far. Probably, more information here than you need or want, but I was feeling "wordy" today!!! This is the same condition that has caused sudden death in healthy athletes who did not know they had this condition.
Thanks again for the concern............. I have come to realize the importance of health and also know that most folks take it for granted. As we get older (63 !!), it is no longer an assumption.
RKrieger![]()
The voltage and current numbers on Modern Marvels do not appear far off the mark.
Take a look at this link from one of the AED manufacturers. Down toward the middle they have some graphs of current versus time and average current delivered. The Zoll system (being promoted by this link) delivers an average current of 20A into a 75 ohm resistance for the during the positive half of the pulse. That really is 30kW and 1500V, but only for about 6mS.
http://www.zoll.com/product_resource.aspx?id=728
-Jon
