green2012
- highland park, il
There is a 200 amp underground service that was installed using #6 to the cold water pipe. The grounding electrode runs 100 feet from the cold water, through the panel, and is terminated outside in the meter socket ground bar. The suplimental ground going to the 2 ground rods is terminated side by side to the electrode wire from cold water. Does this pose a danger? Should the 100 feet of #6 be replaced? What are the potential dangers if any?
