FWD
- GREENVILLE CALIFORNIA
I have a 120/ 240 V. 3 phase 4 wire Delta service on a Sewer lift station . The customer ordered a 60 KW Generator factory connected Wye 120/208 V . The transfer switch is 3 pole with a solid neutral . I understand most 240 V equipment will run on 208 V , but is 120/208 V compatible with the incoming service with the un switched neutral ? Appreciate all replies , thank you .
