EmagSamurai
- Alabama
Is there a performance and/or reliability difference to consider when choosing a WYE wound vs delta wound motor? I was told last week that a WYE wound motor acts like three separate windings and pushes the rotor while a delta wound motor acts like one continuous window and drags the rotor. Also, in this same conversation I was told that wye wound motors are less efficient than a comparable delta wound motor.
I've never heard anything like this before. The business about pushing or pulling the rotor seems to completely ignore the physics of how a motor works. The stator field is always rotating faster than the rotor, correct?
My understanding is WYE wound motors can be built a little smaller, hence they tend to be used in smaller motors (say somewhere around 25 hp and below, but not a fixed rule). Otherwise, the characteristics between the two are similar.
Did is I miss the day this was covered in Power class? ?
