181213-1423 EST
winnie:
Some additional.
Do you need a Variac? That is do you need variable voltage?
My guess is that if you used a 1/4 supply voltage that this would keep you low enough so that magnetization and saturation were not major factors.
In a real transformer if there is no load on the secondary, then the impedance looking into the primary is determined by the primary shunt inductance, primary resistance, and core losses. So an unloaded transformer still presents some load.
From my previous post there is no coupling from transformer 1 to 2 or 3 from transformer 1 load current. But there is some because there is not complete flux cancelation in transformer 1. This flux difference is possibly in the few % range.
The leakage flux is that which is not contained within the magnetic core. Some of this will interact with any coil within its field. That field being outside of the core, but can interact with a coil that is around the core.
This may sound like nonsense, and possibly it is, but at this point I have not created a real intuitive model in my head.
