JEFF MILLAR
SHORT CIRCUIT PF % = R / Z. and. Z can not be calculated from the X /R ratio. The value of R or X must be known to calculate Z from X / R.
Bottom line here is LV circuit breakers need to be derated if the short circuit X / R is greater than 15. There is a table for this correction factor.
When PF % O.15 is given with X/R 6.6 as lv circuit breaker test values, this turns out to be useless information. And caused my mental block. Now unblocked.
