paul renshaw
- Cordova, Maryland
When calculating the conductor size for the secondary conductors of a xfmr, do you have to add anything to the max output amps of the xfmr? Say it is a dry type step down and the output amps are 125amps just for an example. Can you size the wire for 125 amps, because it can be actually fused higher if the xfmr has primary and secondary OCPD.
