mbrooke
Batteries Included
- United States
- Technician
Where would XHHW-2 and RHH be used over THHN/THWN-2 in building wiring and underground conduit runs? I can't imagine a specific scenario or advantage.
Yes, I’ve been recommending that for years now. I heard about it but ignored it, then I started to see older installations where I could notice burn marks at regular intervals along the motor leads where the corona discharge burned right through from phase to phase. In one case, the leafs passed a megger test because there was no leakage to ground, but the VFD was picking up the p-p fault.
With PWM outputs, there is a capacitive coupling effect in the adjacent conductors created by the high speed pulses that creates a "standing wave" of higher voltage on the conductors, which then travels to a point of change in impedance (the motor terminals), then reflects some back, until it hits another change in impedance (drive terminals), and reflects back again, building up all along, like ripples in a pond building on each other to make higher peaks. This "reflected wave phenomenon" (look up that term) can result in voltage peaks that can reach 2-3x the RMS voltage.
Also during the evolution of VFDs, IGBTs replaced earlier GTO and bipolar devices because its faster risetimes enabled higher carrier frequencies and improved efficiency allowing smaller heat sinks. But faster risetimes also made signal reflections become an issue at shorter cable lengths. When the propagation time through the cable (which is proportional to its length) becomes more than about 1/2 the risetime of the VFD output waveform, then the cable starts behaving as a transmission line and reflections can become a problem.Decades ago when I first started working woth VFDs, we worried about motor lead lengths in excess of 100ft., believing that it took that much cable capacitance to cause it. Then it became 75ft after alot of people started seeing damage, then 50ft, then 25ft. Now, it's known to not be totally dependent upon length, although under 25ft it does seem to be rare.
Good to know this. Are you saying that the output of a VFD should be XLPE insulation?
