Hi guys, new to the forum. Came across this thread while searching for something else online.
I don't want to come across as spam, so I will do my best to cover questions without trying to sell my services.
There are basically two types of inspection for concrete coring. One, as you guys have discussed is concrete x-ray.
The other is ground penetrating radar.
Like most tools, each has advantages and disadvantages.
Radar has the ability to scan the concrete from only one side, as a scanning devise, it is recommended that each core has a 2'x2' area around it clear for movement of the antenna. There are no harmful energies present with radar, so most jobs can be completed during the day while other trades are present. Also, since only one side of the concrete needs to be scanned, slab on grade is not a problem. Actually radar is about the only imaging method available for slab on grade.
The disadvantage to radar is that it is almost impossible to differentiate between rebar and post-tension cable. I know, I know, so and so company said they can, the manufacture of the radar said you can etc. It is possible under certain circumstances, but that is the exception. Also, plastic conduit is very difficult to see with radar. The reason is simple, radar works by somewhat measuring the dialectric constant of the medium that it is going through. As far as radar is concerned plastic (PVC) conduit has the same dialectric constant as concrete. Again, there are exceptions, but as a rule we say "best effort"
Concrete x-ray needs access to both sides of the concrete at each location to be drilled, as a rule of thumb, we need as much room as the core driller needs top and bottom. Typically, you mark where you want to drill, and the x-ray crew will locate the bottom side. Depending on concrete thickness, you will need to clear a 50' radius around each location of all non-xray personnel. Barrier tape will be posted to keep the area clear. Many times it is more productive to xray after hours.
The advantage of xray is we can see basically everything in the deck. Rebar (including size), conduit, with or with out wires, number of wires etc. and post-tension cable.
It is our belief that you need to have both, and use them accordingly.
One extra thought to keep in mind, our radioactive materials license from the state of California is very expensive (yearly), the paperwork involved with our radiation safety program is very time consuming, and the amount of support equipment involved with xray is very expensive. I.e. Fullsize trucks with mobile darkrooms, two men on the clock for every xray job ect.
Radar has virtually no support equipment, can be dispatched out of basically any car, needs only one person on the clock, etc. Our margins are much better with radar, why do we still do xray? Because it is necessary at times.
Sorry if it was long winded, let me know if you have any questions..
