I recently set up a rotary phase converter for a friend. It used a 40hp 3 phase motor, some caps and was commercially purchased unit. The circuit was pretty simple and I decided to set on up for myself. I got a 40hp motor and set up the motor same as the other unit I installed. I did not realize that the motor I got was a y start delta run. Well it didn't work the way I wired it :-? so I don't know what to do now. Does anyone know if a motor of this type can be used as the idle motor in a phase converter situation. If so does anyone have a wire diagram. The motor has a high or low voltage and has 12 wires from the motor.
Thanks
Fritney:
Thanks
Fritney:
