Being a bit of a connoisseur of dams
:.... (and this is based on memory, too lazy to dig out the books).
Those four towers- the inner two are the penstocks and the outer two are spilllways.
There are 8 generators on one side and 9 on the other, don't know why. They were very well built, but they've also been rebuilt for higher output. They also have to replace the turbine wheels every so often. IIRC, the shafts are only about 18" dia. Also, the governors are original (as of 1999), various 3 coil motors, transformers, and hydraulics. It was kinda fun to watch the gate angle meter wobble back and forth to keep the rotation constant.
The main gen's are excited by 250vdc at 1200+ amps. Got a photo of the rating plate somewhere.
Each side has a "house power" generator, which looks absolutely TINY next to the production units. Tiny is a bit misleading- the house power gen is something like a 3' (!) Pelton wheel turbine and a 2MW generator. With a 400'+ head, that's a lot of power. The facility can black-start itself.
I did the hard-hat tour a couple of times in the late 90's. Absolutely amazing. BTW, the primary mission of the dam is flood control, not power generation. The guide said the lake would silt up enough to be a problem in maybe 500 years.
