jxofaltrds
Retired ESI
- Mike P. Columbus Ohio
- Creator
If you need a good laugh today then read this:
http://activerain.com/blogsview/1482390/trusting-your-gfci-test-button-could-kill-you-
Just a part of what he says:
"Are there any situations where a GFI will not protect me from a dangerous shock?
GFI's are not effective in certain circumstances. As mentioned earlier, they work by measuring the difference between the electrical current going INTO an appliance and the current going OUT of the appliance. This assumes that the person being shocked is grounded. If you were ungrounded and touched the hot and neutral wires at the same time, there would be no drop in current detected, so the GFI would not activate. Then, you would be at the mercy of the fuses or circuit breakers, which may or may not stop the current before its too late!
A second situation where a GFI will not protect you is when a second, unprotected circuit is involved in an accident. This can happen when a wire is accidentally drilled into or a metal screw penetrates a wire hidden in the wall. Unless this second circuit is also protected, you are at full risk of electrocution, even if the tool itself is on a protected circuit!"
I love his source: http://www.naturalhandyman.com/iip/infelectrical/infgfi.html#7
